TBH I think the stock head gasket. At some point the stock bolts give up and you need to use studs, but I'm not sure where that crossover point is. In my head I remember JZW or Nick having an opinion on that, and I'm sure it's in the 500+hp range.
This is 100% my ignorance, but in today's terms I don't know what copper gaskets actually solve. In the old days of simple gaskets and less advanced clamping there was definitely potential value from copper, but modern MLS gaskets with the right hardware can withstand a LOT of pressure. On my XR4Ti I use a Cometic MLS gasket and ARP studs - it's been handling 25psi for 15 years. In the GM world, I see people making close to 1000 boosted hp on stock LS-whatever gaskets. A friend has a 600hp Ecoboost Mustang on a (revised) factory gasket... It's at least 25psi and it could be 35psi. MLS gaskets are quite good.
My suspicion (I don't know) is that on a Saab the big issue is clamping. The stock bolts aren't super strong, and they're TTY, so it's probably possible to generate enough cylinder pressure to loosen the bolts and that will blow out the gasket quickfast. If you have adequate clamping, I think that gasket is going to take a lot of pressure. The problem of course on a mixed-material motor (iron block, alloy head) is that you have different expansion rates... the MLS gasket and TTY bolt configuration is designed explicitly to handle that. When you change over to studs, you will lose that elasticity that keeps everything together. That may end up with secondary issues, which is probably why Nick doesn't recommend studs until you absolutely need them. On my XR, the head and block are both iron (yay?) so that's not a concern for me.
But studs on a mixed motor will probably result in a relatively short lifespan for the gasket and/or ongoing need for retorques. Of course, ARP's metallurgy is quite good, so who the **** can predict what actually happens?
Maybe that's a reason to use copper? The gasket probably won't blow out if you lose clamping? IDK.
