1 - 2 of 2 Posts
Hello, I have a 2004 9-3 Aero with AC problems. At first I thought my AC system needed charging because it was just blowing hot air. After hooking up gauges everything checked out okay. I then checked out the fuses and found fuse #36 was blown. This is one of the maxi fuses in the bigger engine compartment fuse box. I replaced the fuse and my car started blowing cold again however the fuse keeps blowing. I am guessing one of my cooling fans is going bad. I just joined the forum today to try to find a solution, Any ideas? Thank you in advance for any responses.
1 - 2 of 2 Posts
