Just last weekend as i was returning home, the dreaded "coolant level low" display popped up and upon my arrival at home I discovered that my heater hose had an inch and a half crack in it and had nearly spewed all of the coolant all over the engine. luckily, it didnt overheat or anything because it happened when i was very close to home and i had shut the engine off pretty quickly after it happened. my question is, what kind of coolant do you guys recommend, because after reading a post on thesaabsite: http://thesaabsite.com/Coolantinfo.htm im a little leary about what kind to refill with.
thanks for your help.
