To make this quick to read:
1989 Saab 9000 CD 159k miles
Brother purchased car for $100
Car had been sitting for 3-4 years unused - white smoke coolant loss issue began on immideately following purchase on the way to my house (coolant fan temp switch failed and caused overheat)
While running liquid coolant would drip onto ground from large cracks in exhaust at the cat connection
While not running liquid coolant would sometimes drip onto ground from the same location
I assumed bad head gasket and performed the repair
Elring head gasket kit from Eeroparts.com includes new head bolts, intake & exhaust gaskets
Head was resurfaced
Block was cleaned
Torqued in sequence from 44ft.lbs then 59ft.lbs then 90 degrees
NOW:
While running white smoke starts immediately and liquid coolant drips from exhaust (same as before gasket replacement)
All 4 cylinders have exactly 135psi
With plugs removed all cylinders appear dry and no cylinders are shiny (I haven't run it more than a few times around the block since repair)
Pressurized coolant system to approx 15psi
Coolant starts dripping from exhaust and all cylinders appear to remain dry
Rotating the crank introduces coolant into cylinder 4 when intake ports are open!
No matter the crank or valve position coolant drips from exhaust when the coolant system is pressurized
QUESTIONS:
How can coolant enter through the intake port on cylinder 4?
How can coolant drip from exhaust even when valves are closed and no coolant is entering the cylinders?
Can a bad turbo seal leak coolant directly into the exhaust system?
Is it possible that I have two issues: A leak past the intake gasket into cylinder 4 intake port (intake manifold did have some pitting) + an internal turbo coolant leak (to account for the drip even when intake port is closed)?
NEXT STEPS/MY PROGNOSIS:
Slide video scope down intake manifold and view near intake port to see where coolant is entering/pooling
One possibility is that the head could be cracked between the water jacket and intake port
THANK YOU FOR ANY INSIGHT ON THIS ISSUE - I have read other posts extensively and my issue seams pretty unique from what I've read
Head was resurfaced
Block was cleaned
NOW:
QUESTIONS:
