There is a problem with my 2003 9-3 ARC sedan because every couple weeks I need to refill the coolant. The error code says the coolant is low and needs to be refilled. I keep having to buy more coolant and it is rather annoying.This has been going on for months. Finally I took it to a shop and they did a pressure check and looked for leaks. It came back as nothing wrong yet it kept happening after the fact. I took it to PEPboys this time and they too did a pressure check...came back ok. They also put a dye in the coolant so they would be able to see where it was leaking. I brought it back and they couldn't figure it out. What could be causing this to happen because this is not normal? (also I have been told it could be leaking into the engine but I dont have white smoke coming out the exhaust nor did the dye show up there)
