Hi guys.
There's a hose going from the TB to somewhere near the head.
This hose passes under the IAC and has a little hole in it that spills lot of coolant under the plenum.
Does anybody got any idea about the cost of this hose and if it is hard to change?
Thanks.
http://www.eeuroparts.com/(akyqnz45itsxj2q1mso1afu0)/home.aspx
Hose 12, preformed, it appears to be @ $$9 American dollars, could be a lot worse. About 10 years ago VW had their upper radiator at nigh $90.00! I made a better one for about $30.00...its easy to do..
The labor, IMO, should be no more than 0.5 hour....add to this the upper hose, as necessary, maybe the heater hoses..
BTW, I'm as tight as they come - if the hose is still passable, slip in a short copper nipple if you can find a piece of the right size ....but for $9 why bother..
Thank you very much.
