So, I had a leak on my 03 9-5 Aero and took me over a month to pin point it. It is coming from the weep hole in the back of the turbo just below the banjo bolt.
Does it mean the turbo is done or can it be repaired. What are my options?
Also when driving the car it has no power, as if the turbo is not working at all and when I give it over half throttle it starts misfiring. Would this be related to the turbo or is it something else?
Checked as follows:
compression 125-135 psi on all 4 cyl.
fuel pressure 35 psi
voltage to all injectors but don't know how to check if they are working right.
Checked as follows:
