I have been hoping to find a different possible cause for my coolant leak. Losing an inch or more every few days from reservoir.
Had oil tested, very low sign of water (probably because I mentioned it when giving the sample it was noted), everything else normal.
Nothing on ground, no creamy oil or coolant, no smell.
No visible signs of coolant in exhaust.
Just did a compression test, equal across all four cylinders. Bad news is it was 149-150, should be 179-180, right?
So unless the tester was faulty it points to head cover gasket............?
