Vehicle in question is a 1998 900SE
So, I've spent the last 24 hours or so reading through the archives, have followed many tests and tips, and I think I've identified the problem. First I'll give a little background.
-water pump replaced last year in june
-no engine overheating
-no oil in expansion tank, nor coolant in oil
-slow loss of coolant level in expansion tank, maybe 1-2L per 5 hours of driving. i've been topping off the loss with filtered water.
-slow visible drip/seepage at idle from what appears to be a bolt connecting water pump assembly to engine....drip speeds up when rpms increase.
** a note on the location of drip - after removing the grille, and passenger (US) side headlight, i can light up the area on the front of the engine, and the leak is coming from below the top of the water pump, and above the a/c condenser unit. i say below the top because it is not visible from above.
SO
is it likely that i've blown another water pump in a relatively short period of time?
could it be a seal in the water pump? i've seen a $1.99 seal part for the water pump on one of the websites.
any advice will be appreciated
cheers
-Matt
SO
cheers
-Matt
