1 - 11 of 11 Posts
can anyone tell me where the cylinder block coolant drain is on my H type 99 engine? Haynes just says right side of the block but I'm drawing a blank.
Welcome to Saab Central :)
Under the exhaust manifold (do it when the engine's cold unless you like burns ;)), there should be a very large bolt head (for putting a block heater in) and just above or just below that should be the drain plug. I'll see if I can find a pic.
I think my B engine has that little plug below the big one too, however, IIRC the hole in the block doesnt actually go all the way through - so its not actually any use as a drain! (its just an external hole which is plugged by that nut)
makes sense. I shall check again on my spare block.
the block i am using should have been given a good clean, so that should have removed the crud!
The first picture is for a late 900 block as it has the extra thing that bolts on with three bolts (and that's the type I have on Blu'y now - much easier to get to the drain!). The second picture looks about right.
1 - 11 of 11 Posts
