1998 9-3 SE
I have a coolant leak, steering fluid leak, and found two plastic things rolling around in the engine (see photos). Does anyone know what they are and if they are related?
Not a mechanic at all. Will need to take it to the same shop that did both the radiator and steering work. Sad and annoyed, payed to good coin to have both issues fixed this year. Not sure if there is anything perhaps I can do myself.
Slow coolant leak: gets low every 200miles or week or so. The radiator and associated hoses were replaced a year ago to stop a slow leak. (~$600)
Steering fluid leak: steering rack and tie rods were replaced 2 months ago to fix a major leak. They said the rack had cracked. (~$1400)
Plastic things: were resting side by side on a flat piece of metal below and to the left of coolant tank (when facing the car), directly below the steering fluid tank. The yellow one says 3/8 on top.
Any info and input welcome! Thank you!
