I finally replaced the passenger door lock on the Saab. It was easier than expected with no need to remove the door handle.
Here are the steps:
1. Remove door card
2. Pull back the rubber weather seal. The glue is reusable.
3. Mark the location of the rod in the yellow lock cover with a Sharpie -see picture 4-5. Unlock the yellow lock cover. Without the marking on the rod your door handle may not work correctly. Every mm counts here!
4. Remove the three screws on the lock and work the lock out of the door - see picture
5. Disconnect the cables and wiring.
6. Change the locks, add grease etc as you wish.
7. Assemble as above
Here are the steps:
1. Remove door card
