1 - 7 of 7 Posts
Hey,
When i got the car CEL p0138 and p0140 came up for o2 sensor, cleared codes - noticed poor fuel econ , ordered parts - as i am going to the shop it shut off, ran codes and a p0035 popped up, cleared codes and car started. Luckily im getting sensors changed now, is it probable that the 138/140 could cause the 035 code?
Second question, car has 170k miles its automatic, and drives fine- got the GM Trans fluid from eeuro , i understand when you drain the trans its about 30-33% of fluid, then you top up what you drained. Is one bottle enough? The mechanic said he doesn’t recommend. Whats the general consensus on such a task, i’m just being proactive.
Thanks!!!!
A drain and fill on the trans is around 3.5 liters. Three rounds gets most of the old fluid out.
So they changed the downstream o2 sensor.
Issue that I’m getting after driving a while, is while stopped at a light the car shuts off, can’t start it up immmediatly until it cools or i unplug the battery and reconnect?
No Codes are popping up.
Any ideas??
Thanks
When my ECU was bad, it would be alright when the car was cool, but throw codes as it got hot.
Discussion Starter #6
Driving back 40 miles towards last 7 miles it would jitter , kept my foot on the gas - the CE light would fade (not really flash) but would cease- luckily there wasn’t traffic, made it home and checked for codes (no CE light) and the P0035 code was in the memory.
Another post does mention the ECU.
268599
If indeed it’s a ECM few options i have;
1.) Get a junkyard ecm (can’t seem to find part name on car-part) and it get married to car.
2.) send it in for repair/reprograming - saw some eBay services $159-269 - seems to be the easiest?
Would appreciate any input.
1 - 7 of 7 Posts
