I have been chasing codes on my 9-5. Don’t drive it much at all in winter , only on nice days. I usually check everything BUT the actual part the code references to make sure it’s not a connector, wiring or vacuum leak causing the code.
The fuel pump relay is under dash; my OEM owners manual schematic is not correct for my car. Figured out the correct schematic thanks to Diggs pointing out downloadable manuals. The relay itself? 60 dollars at the dealer. No stock , a week from Lansing Mi. Local ACDelco dealer brought in two different ones, next day service RY255 is the correct relay. $21.08 Canadian including tax. Problem solved
