code p0413
682 5
any help or suggestions to fix it or any idea what it is at all
· Registered
Their scanner didn't give any other details I imagine. I have a 1994 (OBD 1) and the scanner they have at the advance autoparts near me gives me some additional info about the code, ie "O2 sensor low reading" etc. Maybe if you got it read by a different brand of code reader you might get some other information.
What year is your car? I'm not positive which years do this, I know my 1994 does, but there is a way to read basic codes by turning the ignition to the "on" position without starting the car and counting the number of times the CEL blinks
· Registered
P0143 is a generic code for "Secondary Air Injection Switching Valve A Circuit Open"
Beyond that I can't help you.
For other generic codes (second digit is "0") you can look them up here:
http://www.iequus.com/support/obd2_definitions.php
For SAAB specific ones (second digit is "1") there is a post by PMI from another thread that can help you:
http://www.saabcentral.com/forums/showpost.php?p=831579&postcount=8
There are also many other threads on OBDII codes, so do a quick forum search if any other codes come up. Good luck!
