Just today i drove my 01 9-5 v6 right when pull in the parking lot my car shut off. Try to start but it wont start the engine just keep turning. So i waited for ten minute, after that car started. drove about two minute car shut down. waited for and 5 minute car started and droved for 15minute until i maded home. turn off car restart car start fine. Check engine light on so i ran in the house grab the OBD reader code P0337 crankshaft postition sensor a circuit input.
were is this located please help?? is this a easy fix? Have anyone has this problem before?
car has 72k will service
Did you ever find out what it was because I'm having the same problem. I just swapped out the crankshaft position sensor in the car still won't start
You need to check the wiring.
Grab a copy of the WIS in the Tech2 section and follow the step by step fault trace for the P0337 code (if thats the error you are getting)
