I was hoping someone could help me as I have a bit of a problem with my clutch.
I have just replaced my gearbox (manual), clutch and slave cylinder on my 2002 Aero. The problem I have now is that when I press the clutch pedal it just launches itself at the floor.
As far as I am aware I primed the slave cylinder properly. Squeezed out all the old fluid, connected a hose, filled this with brake fluid and cycled the cylinder by compressed air and pressure to push it back in etc...
When I get someone in the car to press the clutch it goes straight to the floor even after bleeding the system. As I look through the small access hatch in the front I can't see the piston moving at all but I can move the release bearing along the shaft with a lever. There's no signs of leaks anywhere in the system either.
Any help with this would be appreciated as I have been trying to sort this out for the last 5 hours and the next step is going to be a rag in the petrol tank and a zippo!
Cheers,
Pug.
Cheers,
Pug.
