The clutch on my 02 9-3 HOT Vert is feeling a little strange.
When I push down on it as it goes past the halfway point there seems to be a little more resistance than normal, it almost feels like the cable is rubbing on something. Like a metal on metal feeling. It still works 100% and there is no slipping it just feels strange.
Any ideas?
Jules
South Africa , interesting place..
eEuroParts shows a hydraulic system.
The operator must feel a resistance at the 1" or so mark, this is where the TO bearing contacts the pressure plate...No man can manually depress a pressure plate without quite a bit of mechanical leverage... - unless Saab is using a "power clutch", where there is no feel..
If the resistance becomes greater than normal, then something could be fouled up - but this is hard to imagine..., particularly on a still new car...
AS you have a 9-3 you shouldn't a cable clutch, you should have a hydraulic package with master & slave cylinders.
2 things before you really get concerned, try lubricating the pivot for the clutch pedal and the union to the master cylinder rod - spray grease will do; have [if has not been done recently] the clutch hydraulic circuit bled.
These two things are easy [and cheap] hits, and even if they don't totally cure your problems the car is better for the tasks anyway.
