Yesterday I was driving around and my clutch started feeling weird. The car was still shifting fine even though the clutch felt 'empty'. About 10 minutes afterwards I found that I couldn't shift at all. There is no action from the clutch whatsoever, however it feels fine. Just no action coming from it. I checked the reservoir and it looked fine. Any ideas?
P.S. the tranny is fine, i can put it in gear when the engine's not running. Thanks
Edit: I can shift when the engine is running, but it needs a lot more force to do so. Clutch still feels empty
Brady, you say; "the clutch felt 'empty' ", then you say "however it feels fine". These are mutually exclusive statements, so it's confusing.
At any rate, from your description of the symptoms it sounds like it's quite possible there is air in the hydraulics. There may well be fluid leaking where you can't see it, but it's possible that air can get in with zero or a very minor amount of fluid leaking.
When the pedal is pushed this creates a pressure inside the system that forces the seals outward against the cylinder bores creating a good seal (but can still leak if the seal edge or cylinder bore is damaged). When the pedal is released the clutch spring (i.e. diaphragm) pushes the fluid back the other way and keeps the seals under pressure and thus sealing. When the pressure drops to zero (foot off pedal) the seals only have their inherent over size to prevent fluid leaking or air entering the system (i.e. the relaxed seal rubber would be a larger OD than the cylinder ID if the seal were not 'compressed' by the cylinder bore, so the seal 'pushes' lightly against the cylinder wall even when no pressure exists within the system).
But, if the seals are old and have taken a permanent 'set' so that in a relaxed state they are no bigger than the bore ID, then when no pressure exists in the system they could slowly seep fluid in one direction and / or air in the other direction. For pressure to rise in the system (and force the seal lip against the bore wall) the master cylinder piston has to start moving, and if the seal is not 'naturally' pushing against the bore wall then this is the moment when air is most likely to enter, i.e. just as the piston starts to move but before internal pressure forces the seal lip outward against the bore wall. The amount of air may be tiny, but over many pressure cycles can build up to a quantity that affects system operation.
Such a leak could be at the master cylinder or the slave cylinder, or both. If I were betting on it then I'd lay some money on it being the slave cylinder, since this will be exposed to higher temperatures than the master cylinder, which is likely to have an affect on the seal.
The short term solution would be to bleed the system. This will probably help, at least for a while (until more air gets in). If / when the symptoms return, since it appears necessary to remove the gearbox to access the slave cylinder, I'd replace the master cylinder first and see if that fixes the problem longer term. If not then the slave cylinder probably needs changing.
If so then I'd also be seriously considering replacement of the clutch and the rear crankshaft oil seal while the gearbox is off. Even if these are currently in OK condition, if they're 'getting on' then they could start failing at any time, might as well replace as preventative maintenance to avoid having to remove the gearbox again in the possibly not too distant future...
This doesn't mean that the problem is definitely the hydraulics, there could be some problem with the clutch itself, or the release bearing / mechanism. And of course, make sure the system hasn't 'sucked air' due to low fluid level in the reservoir...
Regards,
John.
