I have a SAAB 900i Convertible 1993, Last of the classics.
I have a clutch problem and can't diagnose the cause.
It does not engage first unless I pump the clutch 10-20 times then its works fine for a little while, 10-20 mins, but only at the full depression of Pedal.
There is some minor fluid leakage under car but very little.
I have had the fluid flushed for a very slight improvement.
There is no clutch slippage.
I was thinking Master cylinder or Slave but my mechanic thinks the fingers on pressure plate are fatigued and that I need to replace clutch plate etc.
I love my Convertible and dont mind spending the money, but I would prefer not to have work done thats not required.
So my questions are.
Has anyone had a similar issue?
Should I replace Master and Slave first and then Clutch plate etc if that does not work?
My mechanic wants me to source parts so,
Any good suppliers you could recommend preferably in Australia.
OR Any reccomendations of good SAAB Nechanic in Brisbane
Lastly should I just go with OEM or is there aftermarket parts which could be better in terms quality etc.
ps before I bought the car the previous owner had a recon Master and Slave fitted a couple of years prior and the drove it very little.
Thanks Martin Ipswich Australia
Also I have a SAAB worksop manaul and and happy to email any sections anyone may require
