1 - 2 of 2 Posts
I noticed that after the clutch pedal returns back to its native state, it makes a snapping noise..
It appears that this has been an issue on older models (2003 mostly)...
The spring appears to make a noise just after the pedal cannot move anymore...
Discussion Starter · #2 ·
fixed the problem..BUT
as I was getting the spring assembly back into position, I must of moved the clutch petal out of proper alignment.
As a result, the car would not start because the pedal did not reach far enough to engage the starter button. To fix that, I put on a temporary 1 inch chair leg scratch pad that is about 1/8 inch thick...
Now it starts until the self adhering pad falls off... Maybe crazy glue on a more perminent pedal extender...
1 - 2 of 2 Posts
