Hey, i'm new here. I have a saab 9000 1989 model. The problem i have is that there is no pressure in the clutch, the clutch doesn't go to the floor and stay it, it returns fine just no pressure cannot disengage the clutch at all.
It has recently had a master cylinder kit, and i cannot physically see any leaks around that, so i'm assuming that is fine.
Clutch/brake fluid is below minimum and with the car running brake fluid is leaking onto the floor below the gearbox. I am assuming my problem is the slave cylinder, but just wanted some other opinions. Should i be checking anything else first like hoses etc running from the resevoir, or is it definately slave?
If this is the case, i'm assuming the slave cylinder is inside the gearbox (why i do not understand) and what is involved in removing the box?
Thank you in advance for any help, and i do apologise if this has been covered before, i did have a search but couldnt find exactly what i was after.
Max.
Max.
