My clutch isnt fully disengaging when i push the clutch pedal in all the way. i tried bleading the clutch, didnt work. I took the pedal off and looked at it and nothing wrong. i cant figure out why it isnt fully disengaging. This is very very frustraiting because i cant drive it and i need it for work. Does anyone know what could cause this? the clutch slave silinder looked in good condition when i took the tranny off, the clutch disk is brand new... PLEASE HELP
How did you bleed it? It needs to be pressure bled.
David.
Banned
Likely your Master cylinder has failed.. Very Common, relatively inexpensive to have fixed, usually less than $200.
Ohhhh avoid 'Swedish Motorsports' at all costs.
Okay then, it could be either the master or slave cylinder, I changed my master cylinder first, cheapest option, it turned out to be the slave so gearbox out I'm afraid. There were no visable signs of slave cylinder failure, however putting a new one in fixed it.
