Replaced front end links with factory replacement parts about 2K miles ago.
All was good, no more noises and a nice ride.
Suddenly a new clunking/knocking noise from the front left when encountering dip in road.
It’s not the same banging noise that I felt when I went over small bumps/potholes in the road prior to replacing the end links.
I’m thinking upper strut bearing or possibly lower control arm/ball joint.
Is there a way to determine the condition of the strut bearing without removing the strut assembly from the car?
Same applies for the lower control arm, anybody have a recommendation on how to determine if that is the issue?
I verified no loose bolts on suspension components and no issue with recently replaced end links.
06 9-3 SC Aero 6 speed manual with 120K miles, completely stock, original struts/shocks front & rear.
