In my effort to restore my saab to full working order, one of the other problems my saab is having is the climate control doesn't do anything.. It is on full blast, even when i turn the temp all the way down or the fan all the way down. the off button also does nothing. I have read that the fan controller sometimes goes bad. Same issue?
Have you put your ACC through the diagnostic mode yet?
Press AUTO and OFF at the same time and hold until the screen goes to zero. The system will begin checking itself. If the ACC detects that all is normal, the screen will remain at zero, then go back to normal. If errors are detected, the screen will display the number of faults it finds. IIRC, the number on the screen isn't a diagnostic code, just the number of faults found.
At least this way you'll be able to tell if the problem lies in the ACC unit itself or somewhere else...
