Yesterday I noticed that I have a clicking noise coming from the dash, most likely behind the gauges. Being that it only happens while the car is moving, I'm suspecting the speedometer cable. Whenever I ran the heat the speedometer needle was wobbly from 20-40 MPH (but was fine otherwise) and was randomly wobbly without the heat going. Are my suspicions correct?
Not much to go on, but I would say that you're onto something there -- likely in the cable.
I know this sounds a little nutty, but you may take a look at your grounds. Could be a contributor.
You can lubricate the inner cable, you need to remove the outer cable from the gearbox end, then pull out the inner cable, grease the inner cable then refit.
