I4.
just bought the car, 76k miles. it has a clicking noise from the engine bay. assuming its something in the valve train. im currently running 89 for the gas, and i just changed the oil and used 5w30 mobil 1.
also what are some better shocks for it. figure it could use a change, but im not looking to spend *** loads on them. just want a good ride.
will need rotors at some point too (current are a lil pitted), but thats for later.
thanks
Hi, welcome to SaabCentral..in answer to your questions
  1. Is the clicking continous or does it come and go? The ACC compressor clicks as it engages/disengages, if its an earlier auto it will have a brake vacuum pump that can be quite noisy as well.
  2. There's not many budget shocks out there for the 9-5, those who upgrade get either Koni, Eibach or Bilstein set-ups that lower the car and improve handling 200%. They are not cheap but still cheaper than buying Saab OE shocks.
  3. OE rotors are expensive too :roll: , there's quite a good choice of replacememts out there, inc. Black Diamond, Brembo or Ferodo.
continuos at idle wether or not the a/c compressor is on.
my dad was wondering if they were solid or hydraulic lifters, but a quick google shows they are hydraulic so that eliminates that.
MIKE
Have you checked all the pulley belts? One could be frayed and striking an engine component every time it goes round, making a ticking sound. :roll:
Mike
Unfortunately hydraulic tappets (lifters) can click.
Usually on older engines with a high mileage, the seals leak a bit and oil pressure drops with age.
Usually it stops after a minute or 2.
Any half decent mechanic should be able to tell you straight away if that’s the problem.
I think Kermits most likely right, I would check the pulleys and belts first.
Pete
Discussion Starter #6
GONE FISHING said:
Mike
Pete
will check the pulleys. but ive been able to say that the ticking will not stop on idle. even after a 10 min drive it wont. but i cant hear it when reving, only idling.
MIKE
