Being doing lots of little stuff.
I decided to go back and add some butyl sound deadener to the floors. I ended up buying Fatmat megamat. Seems to work pretty well
I added a keyless entry kit. My SPG had an aftermarket alarm with central locking and remote window control. I didn't want the alarm and didn't really need (or want to wire up) the remote window control but I missed the keyless entry. The white car came with a 5 wire actuator already installed in the door. Three wires go to the central locking unit and two go to the keyless controller. Installing this way as opposed to the way show on twinsaabs with a simple 2 wire actuator leaves you with functioning central locking as well as keyless. All you need is two wires to the drivers door, power and ground. The central locking wiring remains intact. $17 on ebay for the controller and you can pick up a 5 wire actuator for between $10 and $20.
Had my 8 year old help me strip all the uselful electronics from the SPG. He loved it. He kept asking if he could take more stuff off. Pretty soon he was handing me all the vent ducting and the heater vent control valves. I didn't have the heart to make him stop.
Today, I pulled the new drivers side axle and hub with new wheel bearing and ball joints from the SPG. I had a bad boot on the white turbo and figured that I may as well grab it all. Removed it all and installed as one piece. It was surprisingly easy to do like that. Last piece I am going to remove before getting rid of the SPG. I have removed everything of value that I could use on my turbo or that I have room to store. I even pulled and installed all the tinted windows while going through and fixing all the felts.
Anyone want an 88 SPG shell with a good motor and tranny? Pinion bearing whine, but no other apparent problems. I don't have any place to store it.
Free to a good home willing to have it towed from my driveway. Otherwise it's going to be crushed.
