Ok
In the event that my APC is faulty and i replace it with a MBC, will this affect a chips performance?
I do want to chip my car becuause they seem to yield the best gains but if a MBC is going to make the chip not worthwhile then im going to shell out the $ for a new APC?
But i think i would be able to set the boost with the controller for the chip?
Well as always
Thanks for the help
Brian
you can increase boost only slightly with MBC without chip due to fuel cut off, which is lifted above in the chip so you will have to get it chipped sooner or later.
Thanks
I was just worried if replacing the APC with a MBC would affect chip performance
Like in the event the chip was designed to work only with a APC
Brian
