1 - 11 of 11 Posts
2004 Saab 9-3 convertible Arc I just recently changed the purge canister and put new spark plugs still getting misfire reading not sure if it's the vacuum engine holes or should I just change the camshaft sensor??
How do you know only 1 cylinder is working? What codes are you getting?
engine won't run with 3 cyls not firing..there is no camshaft sensor..post up the code/s
I changed the purge canister put new spark plugs in Nanaimo attempting to change the crankshaft sensor
Formerly had 900s have a black 2005 9-3 ARC auto at present
what plugs did you put in and what gap?
Better to see what codes it has before blindly throwing parts at it imo
He'll get back to us when CPS fails to fix it. I think Nanaimo = NGK, autocorrected. So that comes at 0.9mm if he got the right plugs.
I'd like to meet the coder who invented autocorrect. In a dark alley. 🤣
EDIT: I also strongly suspect he cannot read codes yet
You are 100% correct I cannot read codes I'm not a mechanic just the average Saab owner for the last 15 years I currently have two Saab convertibles a 2002 and a 2004 9-3 Arc and my everyday driver is a 2005 Saab 9 7x SUV!! Not a mechanic just a Saab lover
Discussion Starter #8
I will read the codes off to you when I get them from the mechanic he wrote them down for me!!
Cool. No sense spending more time and money without a better idea what's up.
EDIT: Ask your mechanic to read the misfire and knock counts, too.
You have 3 cars and no code reader? Buy one already.
  • Like
Reactions: okcrum
1 - 11 of 11 Posts
