Does anyone have the list of what the numbers of "check engine" flashes when the ign key is put to 'run' mean?
I have 3 & 6.
cheers
Dan
swedishwrench.com
sorry i can't be more specific but it won't let me link, go into features / fault diagnosis / fault codes
hth
I took a note of the codes last time fine flashed.
2 Flashes Map Sensor
3 Flashes Intake Air Temp Sensor
4 Flashes Coolant Temp Sensor
5 Flashes Throttle Position Sensor
6 Flashes Lambda Probe
7 Flashes Fuel Air Mixture
8 Flashes EVAP Valve
If you decide to change the Lambda Probe, opion seems to favour a Bosch replacement instead of a generic one - more reliable and longer lasting. I bought my Bosch one with the correct connector for £60 + vat. The only slight problem was that the wire was not long enough to follow the original route and use the original fixing brackets and it had to be re-routed. If buying again, I would call and ask for an extra foot of wiring to be used.
