I have a 97 saab 900 se 2.0 turbo. 150K
Last fall the check engine / Check gear box lights came on and my saab was stuck in Limp mode. This happened off and on all winter. I never could find a pattern of when it would work or fail. However, when I stopped using the alarm system over the summer the car ran great.
Here is a short description of the issue.
About this time last year the tranny went into limp mode. After searching the forums I replaced the NPS (neutral position or safety Switch), but had no change.
I Replaced Battery with no change
Flushed the Trans with no change
In May the alarm system would not turn off with the Fob. After 30 minutes of trying it i was finally able to disable the alarm. Not trusting the Fob anymore I stopped setting the alarm (just locked the doors with the Key). As soon I stopped using the alarm the check gear box light went out and everything worked Fine for about 6 months. Until this October. Now the Check gear box light is back on.
To me it appears to be an electrical issue. Wondering if it could be related to the weather since it appears to run better in warm weather. Maybe a ground wire or a harness that contracts as the weather gets down closer to freezing. Just looking for some hints on where to look for electrical issues that could cause the vehicle to go into limp mode. Below is a list of other strange issues that happen when the check gearbox light is on (which is why I suspect electrical) Plus the fact that the transmission shifts perfectly when the light is not illuminated.
Other current issues:
1. Head lights - could be headlight relay issue??
Headlights turn off when switch is set to ON - unless Check Gear light is off (then the head lights are always on)
Headlights turn on when switch is set to Off - always
2. While check gear box light is illuminated (system in limp mode) the Radio will turn itself on and off randomly. (this does not happen when shifting normally)
3. Trouble disabling Alarm system (new FOB batteries make no difference)
Any help is appreciated.
