1 - 14 of 14 Posts
Well, Spring is here and its time to take off the winter tires and put on that nice sticky summer tread. I just completed this task today, and I was wondering, what are you guys using to change the tires?
I have been using the included wrench and jack in the trunk. The wrench is fine, but I would like a nicer one so that I could get more leverage. Anyone know what size the lug bolts are?
The jack is just a pain in the ***, but it has that notch in it, so I don't know if my options are limited or not? Can I get a regular floor jack and use it on the same spot as the included jack? For those of you who haven't taken a look in your manual (or in your trunk), the jack has a notch it it which locks into a rubber piece on the frame. Is there a floor jack which is better for this kind of car?
I'm just loooking for better solutions for when the winter tires go back on this fall.
Using a floor jack is perfectly fine and easy to use. The lifting points are easy to identify. I don't know the size of the lugs off the top of my head.
The notched "jack points" are just for complete idiots who have no idea what they're doing. You can put a jack anywhere along the the pinch weld or the subframe. I do the subframe in the front and the pinch weld in the back. I use a regular old floor jack and a cross shaped tire iron.
The wheel bolts/lugs are 17mm across the top. Best thing to use is an extending wheel bar, but remember to close it when re-tightening, you don't wanna overtorque the bolts.:roll: I've got some new wheels to put on when i get around to it, will post piccys soon.:cool:
Hey guys, I posted a similar thready in the 9-3 forum, just swapped my wheels for summer.....
Those of you who use floor jacks on the stock jack point/pinch weld - Don't you worry about marring the paint/undercoating? I did mine today, with a wood block wrapped in a towel, and still managed to scrape off some paint. I could see a little bare metal here and there on the jack point. I wiped it off, and applied some touchup to it, and tomorrow I may do a quick spray of undercoat.
DO you guys notice this too? Is it a big deal? Or, am I anal?
And to tighten, I use a torque wrench and torque to 81 ft lbs.
i put on new brake pads today, used the jack in the trunk...
you guys will probably call me an idiot for doing this but; never try to jack up your car on a surface anything short of concrete! i did mine on my gravel driveway and it worked great on one side and then i narrowly avoided being crushed when i jumped out from under the car while doing the other side and the jack slid out.
Seems to be the thing to have done this weekend.....:lol:
I took advantage of the lovely warm spring weather here yesterday and removed my winter use standard MY04 alloys and fitted my 18" Hirsch alloy wheels.:cheesy:
Yup, as said, lugs are 17mm, and I use an extendable breaker bar to remove the lugs.
Manual says lugs to be torqued up to 110Nm.
Always recheck torque setting after driving for a day or so.
I've got a 'professional' floor jack with a good lift range, so I can use the front jack point, under the front subframe, and the rear jack point which is under the bracket which is the rear towing eye. (You do need a high lift jack to make use of this rear point though)
X
Guest
For ease and speed I purchased a small 2 ton Trolley Jack a couple of years ago. Its so much quicker than playing around with the silly little jacks included in cars. They only cost about £15 / $30 (good for home use)
Finn :)
Finn said:
For ease and speed I purchased a small 2 ton Trolley Jack a couple of years ago...................(good for home use) Finn :)
Good for home use................. you aint never gonna jack up your house with that :nono;
Always always ALWAYS USE A JACK STAND if you are going to put yourself under the vehicle. I won't go under my car even if it was being held up by a floor jack, and you couldn't pay me to go under it if it was being held up by the trunk jack. And Kermit is right on about using a big piece of wood on surfaces other than concrete.
X
Guest
joshd2012 said:
So are you using a regular jack and centering it on the jack points? Are you using any buffer between the car and the jack?
I still use the Jack point but I have put a piece of rubber on the jack (Well actually its a small square that I cut out of an old tyre) :cheesy:
Finn :)
1 - 14 of 14 Posts
