Hey all, I recenlty had to change the key in the battery of my 2001 9-5 and although I was able to find some helpful info here and elsewhere on the internet, I thought maybe I could write a better guide for the community.
First off, before you start you'll need a CR1632 battery. I got mine from these guys. Strip of 5 ought to last a lifetime. Don't go looking locally, aparently Saab keys are the only thing in the US that use these batteries.
Ok, so now that you ordered the battery you're going to need something rougly the size of a paperclip, only stronger. The blunter the end the better, something sharp (Like a sewing machine needle) will just dig into the plastic. You will also need a tiny, flat-head screw driver or other object for prying purposes.
Now, turn the key face down with the key-part facing away from you. On the right side of the key there should be a small hole. Push your blunt object hard into the hole. This will push in on the latch and the back of the key should start coming out, but it probably will not pop out, while you're pushing use your screw driver to dig in and lever the thing out. Now you're home free!
Once inside you can push out the keyless entry circut board from the front pushing on the buttons. Once out you can carefully pop out the old battery and put the new battery in. The old battery had a blue sticker on it. Probably insignifigant, but I transfered it to the new battery just in case.
Now, take the keyless entry slug out to your car and hit unlock 4 times -- this re-syncronizes the key with the car and this way you know it works before you put it all back together.
Finally put the circut board back into the key body and snap the door back on. Done!
Photos here
Photos here
