Finally i have attempted and succeeded in changing my automatic transmission fluid. I've searched this forum so much trying to find a picture of the 5-speed drain plug but couldn't. If you aren't sure what it looks like, then do a search on google images for "aisin warner drain plug" and one of the first images to come up is from a volvo with a 5 speed tranmission too. Job was a little messy since i underestimated the flow of the fluid from the plug. The plug does face the Catalytic converter, but the arc of the fluid doesnt really hit it.
Now, a couple questions:
Firstly, i was under the assumption that the drain plug didnt have a washer, mine does and it is aluminum. Where can i buy replacements online for this washer for next time?
Secondly, I first had my fluid changed at the dealer about 5-6000 miles ago because the fluid looked a little dark to me. Apparently the fluid was really bad and our mechanic suggested that i have it changed again at 5000 miles (DONE!
). While i was changing it i was using a gallon(almost 4 liters) jug to catch the fluid because there should only be about 3.5 liters in there... Our mechanic put over 4 quarts (probably 4.1-.2 liters guessing since i spilled everywhere and i had to change containers). I've now put in the correct amount of about 3.5ish liters. Everything feels much MUCH smoother (use to jerk between neutral and drive). Now after a drive, I checked the fluid while the engine was warmed up and running and no fluid even shows up on the dipstick. When the car is off and sits for a few minutes the fluid level on the stick goes sits about right ( a little on the lower end). How can I get an accurate reading on the dip stick? Should i top it up till it sits center on the dipstick even though i've put in 3.5 liters?
Thank you.
Thank you.
