GM have superseded the part number for the manual transmission fluid for the F35 5 speed from 88862472 to 19351859 a BOT 303 GL4 fluid. It appears to be a little less viscous (thinner) than the standard fluid we have used, which itself was upgraded in 2008 to a 75W85 instead of 75W95. It sells for around 16 dollars a litre ,
http://www.crateenginedepot.com/Manual-Transmission-Fluid-Sae-75W-85-GL4-19351859-P11005.aspx
The OEM fluid is essential in my view for the manual transmission; some labels on the new fluid have it listed as a 70W fluid, but still GL4 which is the important part.
A BITOG member complained of poor shifting with the new fluid, I am always suspicious of anecdotal reviews( lol forums are mostly all anecdotal) but the fact is, GM change specs with a view to improving fuel mileage, they would sell their moms for a tenth of an mpg improvement in CAFE specs...so not sure what to think overall, and in any event the old fluid will phase out of the supply chain I am sure...
Good catch Qwik! When a manufacturer goes thinner on gearbox oil, I'm usually suspicious that there are smaller bearings in there that the thicker lube wasn't properly lubricating. Guess it could be something simpler; like GM's vendor phasing out that particular product, etc.
Good to know. I still have a bottle at home when I changed the fluid on my transmission not too long ago, shortly after the synchro on 2nd started going out.
I was planning on using Redline's 75w90 GL5 fluid with my new transmission.
GL4 is the sub category of lubricant needed for this transmission. GL5 will not help you and may in fact hurt it. I see many F35 transmissions wrecked due to wrong oil. More than that wrecked from shock breakage from driver mod/ power hop.
but meh. I would only use OEM fluid if I were you.
Yeah, I think GL5 is a no-no if the trans calls for GL4 (corrosion issues if my memory serves me). Besides, Redline makes a GL4 (I use it in my Sonett) if you want to go that route anyway.
Mods, can we sticky this thread? The question keeps coming up here, and in the NG900/OG9-3 forums, and I think it's the definitive answer. (For now.)
