Can anyone explain/describe where the vent duct that runs from the center console attaches up front? Inexplicably, the one on this car is missing and I'm trying to determine how much of a junkyard car I need to dismantle to get one.
I think this car has a quirky range sensor with attendant intermittent no start... it does add up that the PO had the ignition switch apart at some point, so who knows what happened after.![]()
The transceiver unit is not mounted to anything per se. It looks like the ends would fit over the screws that mount the rear of the console, but they don't. I seem to recall that my "out of the factory" unit was taped somehow but I don't recall where. They antenna (wire) is supposed to have little tie wraps with studs that hold it into the rear or the console but it's not worth worrying about them. Just wrap it up and around the upper section to get a the highest exposure you can inside the console.Got new duct... and for better or for worse, someone had already removed a bunch of the interior so I wasn't able to see how the key transceiver is supposed to be affixed... looks like maybe just taped to the duct?
http://www.sacsaabs.org/sacsaabs.org/misc/01935door_centerduct.jpg
Anyone know?
