1 - 7 of 7 Posts
Ok so as you may know we've got a 96 ng900 2.3l. Which I believe is obd1 and has the motronic running in it.
While I was overseas the missus told me the CEL light came on (shes been driving around with it anyway)
so fastforward to now and I try and use munki's method for getting it to flash but why is it that it refuses to flash??
Although I suspect the wire I am using might be useless (it was off a cellphoen charger lol) but I've tried sticking a pin into it and grounding it against the screw holding the dock in place.
i've also tried putting a pin attatched to a wire in then grounded it on the body. I even scratched the body paint off one part to get good ground. But nada. Nothing. Light just stays steady.
Although I might have found the culprit, I had to replace a hose a while back as it was brittle and cracked then threw a cel and after investigating I found that the hose next to that one has cracked as well. So I'm fairly sure thats my only problem now. But why no flash????
Also Im fairly sure i need to change the oil as its been a year and 1000kms after. What spark plugs do you guys suggest? its like I can feel it bogging a bit so I may as well get the plugs out of the way when I do the oil.
Pull code
then clear if possible
but another member on here tried to plug their obd2 reader on mine and it didnt read :(
It was sometime last year I connected the reader though. And the CEL was on before that.
just wondering as to why the wire in plug 6 grounded against the body wont work :eek:
Ok so i realized another member emailed this to me a while back...
Ive read it over and over again but I still cant get it to flash lol. can you try adn decipher it?
I get i'm supposed to connect pin 7 to 16. but I dont get the push button that connects plug 6 to 4? two wires?
can I just use two separate hair ties lol and also what order do i do it? cause on munkis blog it says tap the wire into pin 6 before going at it then ignition on then ground. How do I go about it with this one then?
Ok first off, thanks to martin. Secondly,
I got it to work. It gave me code 12. Which means no error??? why give a cel in the first place? after I removed it I started the car and the cel was off. however i turned it on again after and the cel came back on which is no surprise. but why no error??
also how do i turn it off? could it basically be because of one of the hoses i have that have detached from the throttle body? its brittle so i suspect air escapes through it.
1 - 7 of 7 Posts
