I have a '97 900 SE V6 (I know, I know) with 127,000 miles on it. I have a recurring P0432 code - catalyst efficiency low. I have replaced both O2 sensors on that bank to no avail.
In addition, I have a strong odor of fuel in the engine oil. I checked the plugs on the bank with the code, and they are not sooty or oil fouled. I got the car with 126,000 miles on it, so I don't know its history. I've had the valve covers off, and there is absolutely no sludge or varnish in the top end, so I assume regular maintenance was done - or these are recent heads.
Possibly related:
This problem cropped up after the local indie did 125K service and a timing belt change. When the car was picked up, it would barely idle and the CEL came on 100 ft out of the lot. He claimed a couple of vacuum lines were switched. Next day, we discovered a massive oil leak, and the CEL came on again. He said he reset the computer and could not find a leak. A couple of days later, the engine puked much of its oil out of a valve cover gasket. Turns out the intake manifold was re-installed crushing the PCV hose and pressure built up under the valve covers and blew out the o-rings (I fixed this myself - I'm not taking it back to this guy) I now have a scanner to get the codes myself.
Any ideas before I spend $$$ on a catalyst?
Possibly related:
