1 - 10 of 10 Posts
I was wondering if anyone had paid for a custom porting of there throttle body pipe and if so how much did it cost, and if not what was the method of porting that was used
If you don't have a Dremel, it will cost you whatever a Dremel costs plus two or three grinding stones.
It takes maybe a half hour.
I used a file, the dremmel grinding tips I was using kept getting clogged cause the metal is so soft, anyone do it my way?
Or you can use a 1 to 1 and 1/2 inch sanding drum on your drill. That costs a lot less than buying a Dremel, and since the aluminum is soft, still will not take too much longer than 1/2 to 1 hour. Finish with 240 grit. You do not want a mirror finish in this casting.
polishing the general profile has a minimal affect, to actual change the amount of airflow the open surface area must increase, this means throttle body bore out [with new butterfly/throttle] spindle waisting or ideally both.
I originally waisted a spindle down DIY, sorry the picture is poor but I ground away and made flat much of the throttle spindle and fitted neat little flush countersunk screws for optimum flow...
I've since then purchased a fully professionally bored out unit that increased max' open area by nearly 20% that also has a waisted spindle...
Note how neat and flush the screws are, attention to detail is the key here.
I hade my intake transition casting, and my turbo intake casting send out to Extrude Hone, cost was $70 for both parts, but they came out quite nicely.
Raggy, I have an extra TB sitting around, what more can you tell me about the company you had bore out your TB?
is it worth the effort then to bore it out unless it is professionally done. I understand that increasing anyair flow is always better but i would rather have it to its highest potential.
This is one of those mods to do whan you've done everything else you possibly could, and it's a cold winter weekend and you're bored out of your mind.
Unless you're exploring other power options, leave this for last.
That and indexing spark plugs :lol:
1 - 10 of 10 Posts
