so recently i went to a car meet and got a few races in. Then later in the night the clutch started slipping real bad. When i got home and went to turn the car on the next day the clutch pedal was very loose had no pressure and i couldnt go into any gear. It did go into gear while off though so i did some research alot of things pointed to the clutch master cyl so last night i replaced that bled it and the car is the same. Am i going to have to drop the trans and do the slave cyl or is there a special/ certain way to bleed the master cyl on a saab? Lmk please need the car to get to work and back
