1 - 12 of 12 Posts
My car vibrate when in reverse, could be I release the clutch too soon, or may be some other cause like replacing cluch, engine mounting or some other...
Previous owner has swapped tripods from side to side due to wear.
Inner CV joints (tripods) wear and they will vibrate. When vibration is too high, owner usually swap them from left to right and vice versa. Now you do not have vibration when driving, but small vibration when reversing. Usually you do not reverse fast and vibration is much less.
CV joints is what in Swedish is call spindelare? Yes I am smooth with the throtle the vibration is much less. Is it urgent to change it, because I have many things to do before.
Discussion Starter #6
Check your motor mounts.
Set E-brake, look for unusual motor movement when engaging the clutch a bit in gear; forward and reverse.
Discussion Starter #8
Which gear forward, 1st or it doesnt matter, I asume that we need two people for doing this, one checking the engine and one engaging the the gear, is this the procedure?
Pick a gear....Any gear...
I look through the windshield, it's not a subtle movement.
Discussion Starter #10
Finally engine mounts are ok. Probably will be bearings and the inner CV joints as Mimi wrotte in a previouse post. I know for sure that I have to change the left bearing because it sounds when turning left.
1 - 12 of 12 Posts
