1 - 7 of 7 Posts
Replace fuel pressure valve.
I just put a new pressure regulator on it the other day... the one on the fuel rail right?
Yes.
Have you double checked boost control valve?
Hey this is my post . No I haven't checked the boost control valve is this a symptom of a bad boost control valve?
Could someone please help... I just replaced the TPS, fuel pump, oil sending unit, fuel pressure regulator, and sob still won't start... I checked the fuel pressure and it doesn't go above 40psi. And like I said the car will start and barley run with full gas pedal
Do you have codes?
Look up crankshaft position sensor failures on here...i wonder if the symptoms are similar. Just a wild guess.
As far as the gas pedal- are u holding it to the floor when you start the car (clear flood mode)? Or do u just need to keep some pressure on it to keep it idling ?
1 - 7 of 7 Posts
