1 - 7 of 7 Posts
Hi all,
I have a 93' 900 16V N/A. When ever I start the car and let it idle, after about 30 seconds to a minute it shuts off. But if I keep on the gas and let it warm up after that it is fine and runs like a champ. Any ideas of what is causing it?
Thanks
does it run rough before it dies, or does it go from a steady idle to just dieing?
it sounds like your cold start enrichment circut is shutting down before it should, I'm not familiar with the configuration of the 16V setup - I'm sure someone else will chime in. It could be as simple as an errant wire or a bad thermal switch -
1 - 7 of 7 Posts
