09 9 3. I had to remove the wiper arms to replace the assembly when the bushings failed. Installed the wiper arms and tightened them down.
The problem is that the passanger side wont attach. Have removed it twice and reattached but it still wont set into the shaft. The shaft nor the arm is stripped.
Is there a trick to this? The shaft is rotating fine so that's not the problem, just cant seem to get the arm down far enough on the shaft.
996TT, 997TT, Audi TT, Corrado and some that dont run
Did you try a little wd40 for lube?
You have to lift the wiper end slightly upwards or away from the glass to enable it to be fully seated on the shaft. Otherwise the angle prevents it to slide all the way down. I hope this makes sense!
