Can anyone help me with my axle carrier bearing? This is for a og 93 so the intermidiate shaft and companion flange are one piece. My question is i already have my transmission removed from the car so do i actually have to remove the whole alternator bracket and bottom alternator bolt to replace the bearing? Im not exactly sure what holds the intermidiate shaft in, i was hoping i could remove the snap ring on the side with the rubber guard for dust and use a hammer/punch to push the shaft out of the bracket?? I might just take it to the mechanic as ive heard someone say you need a press to put the new bearing on?
Any help is appreciated!
