1 - 20 of 43 Posts
Hey guys, im having an issue connecting to my tech 2 with my laptop to gain security access. I have installed everything per the tutorial, but when I go to connect the tech 2 using the serial to RJ45 adapter and the RJ45 patch cable (The laptop I have is an older one with an onboard serial connector) it won't communicate with the Tech 2. I have also tried using a USB to serial adapter in case my serial port was dead, still nothing, even tried another Tech 2 just to rule out the RJ45 port on the side of mine. Anyone have any suggestions as what could be wrong? I have made sure all the ports match, tried a bunch of different settings and still nothing.
You downloaded the cracked TIS2000 from the software link in this forum and moved files around per the readme.txt?
One thing I will say is that the laptop im trying it on only has xp service pack 2, going to try to find SP3 to install on it.
Ok I just installed SP3 and then reinstalled TIS2000, read the readme one more time to make sure I wasn't doing anything wrong, cracked it again, still the exact same thing. If I go to driver and click on test it says that its fine, but when I go to security access I still get a connection error.
The tech2 has to request security. i.e you have to hook it up to the car first so it can pull the vin when you go to make a change or reprogram something. did you do that?
Discussion Starter #10
Nope, I completely missed that step, doh! Will do that tomorrow, we are not able to do much because the lock cylinder is currently locked (replaced with a new one and it needs to be reprogrammed). I will report back tomorrow after I do that.
Discussion Starter #12
Discussion Starter #13
Well I connected to the vehicle and downloaded the vin, its ready for security access but I still can't connect. Any other ideas?
swap out the ethernet cable they give you for one of your own
Discussion Starter #15
Just tried that with no success, here is the exact error that I am getting.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/[email protected]/31198299005/in/dateposted-public/" title="20161123_090411"><img src="https://c6.staticflickr.com/6/5337/31198299005_ac5e2349aa.jpg" width="500" height="281" alt="20161123_090411"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
But when I go to I/O management and click on the tech 2 and then click on test, I get this message..
<a data-flickr-embed="true" href="https://www.flickr.com/photos/[email protected]/30377193834/in/dateposted-public/" title="20161123_090448"><img src="https://c3.staticflickr.com/6/5560/30377193834_c6b6b4e802.jpg" width="500" height="281" alt="20161123_090448"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
try this, but instead of checking USB see what serial prot is and if it matches. or try usb again and make sure it matches
B)
1) Click Start -> Run -> mmc devmgmt.msc -> Hit enter.
- Device manager shows up
2) Go to: "Ports COM&LPT". Expand it.
3) Check what COM port is under "USB Serial Port"
4) Remember.
(C)
1) Hook up your Tech2. (Serial->USB->Serial adapter->Cable->Tech2)
(D)
1) Open TIS2000.
2) Go to Configuration -> I/O
3) Select Tech2 ->Properties
4) Make sure what's under "Port" is the same as step B4.
Discussion Starter #17
B)
4) Remember.
(C)
(D)
1) Open TIS2000.
Did this, both port #'s match, dongle is on the printer port.
Discussion Starter #18
I also have a passthru j-box device on another laptop, is it possible to use that to program the lock cylinder module?
I assume you can connect to the internet with no firewall issues?
Worth checking continuity on the RS232 adaptor plug for the RJ45.
Do you have a physical dongle connected or are you only using the cracked software from the sticky?
Discussion Starter #20
I have the cracked software, no actual dongle. the firewall on the laptop is disabled, the laptop is really old so it doesn't have wifi and I don't have ethernet hooked up to it for internet, this may sound like a stupid question but do I have to be connected to the internet for this to work?
1 - 20 of 43 Posts
