1 - 20 of 25 Posts
:p
I'm kidding. Sorta.
My dream has been to own a coupe. Here for only two years, '85 and '86 all nonturbo 900S models. I now have found one.... talk me into/out of it.
The car: 1985 900S Coupe. 5-speed. Silver (rose quartz?) exterior, tan cloth interior with sunroof. Peeling paint on hood/trunk/roof. Mileage unknown. New-ish clutch, has sat undriven for the past year (won't start. dead battery, more?)
First off, let it be known that this wouldn't be a restoration. For all you purists, YES that means throwing the bullnose parts in the trash and fitting a full SPG kit & 87+ facelift, lowered on cool wheels (shelbys...maybe) repainted in silver with colormatched SPG panels. Yum.
Now, from research I see that the '85 900S notch was a 8-valve. How... charming. Can I slap a 16v head onto this motor, or do I have to swap motors? Also I have most all parts to do a 16vt conversion: turbo, head, intercooler, piping & hoses, distributor, throttle body, minus the wiring harness, ex. manifold, etc.
So Show I have covered, it's the GO I'm concerned about. How dog-slow is a nonturbo 8v? Naww... don't answer that.
TTIWWOP.
Supposedly the hood is a crappy repaint (no car fire).
Opinions please. Talk me into/out of it.
I say go for it man... you got 2 already. (not like anyone needs to twist your arm, as you're gonna do it anyways. ;) )
Do it! My uncle has that exact car except in a chocolate brown color, it's ultra sexay. Also, the 8v is so fast, it blows my mind :D
Find somewhere you can work on it dry then strip to the bone and rebuild, as it'll be a bit special (one if not the only 2dr 16v in the US) you may aswell, then you can stick whastever engine you can get your hands on in it.
Yeah... There's something wrong with me.
Going to see it this afternoon, try to get it running :cheesy: I'm having bad thoughts, phrases like "airflow" and "viggen blue" keep running through my mind. Weird.
Did I mention its $250?
Buy that car, dammit. ;-)
I've been eying it on CL, and would grab it if I had the space; since I don't, you should.
All the clear-coats from that era are lousy, so don't sweat it.
You will need to do a harness swap to run Jetronic, or skip that and do MS.
CC the 8V head to see what you've got before deciding on a head. A 16VT engine is cheap from the PaP, though. Another option: NG900s are showing up in the PaP; I recently bought a 97 head for $25. See my blog and also saabrally.com for more info on that swap.
Do it.
But keep the pre-facelift stuff, unless you have all the post-facelift SPG stuff already.
Notchbacks are so cool.
Oh, and 16v swap.
:p
Swap the engine, way easier.
You need to alter servo, timing-chain, head, manifolds, harness...
Swapping is easier!
Daniel
I think you should leave the outside and make it a "sleeper" or rat-rod, dirty and manky on the outside but tuned to buggery under the hood.
Also I reckon you should stick with the stock engine, but stick huge carbs on it and nitrous it, go for something a bit different, 16v has been done...:lol:
you got on your hands the best looking 900 body style cars the notch back 912.
i love them they are rare fix it right up install a 16 valve turbo upgrade the breaks and suspension and you will have a sweet ride.
sdenton
Between the odd rims and rust problems that looks exactly like a friends '85 BWM 325e.
You already know what you have to do. ;) I don't think it's rose quartz otherwise it would have a maroon interior.
Piggy-backing off your question about swapping a 16v head on, would I be able to put a 16v turbo head on a 16v n/a block? Would any of the 2.1 or 2.3l heads fit, and would that help me lower the compression ratio?
Just didn't seem like it was that big of a thing to start a whole new thread on.
And if that car's only $250, you'd better buy it...If nothing else keep it from getting junked.
The 8V has lots of torque - they're slow when compared to a worked 16V Turbo like your 'vert - but off the line they can hold their own pretty well. I'd keep the pre-facelift front (partial to them myself) and build an 8V turbo engine for it - sure you'd have plenty of turbo lag - but when the boost came on - man howdy!
It'd be a great autocrosser - the coupe was the stiffest chassis built in so far as I can tell. Should be lighter than the hatches or four door coupes as well.
PaulH's old notchback:
Way too cool.
Keep the flatfront!
1 - 20 of 25 Posts
