Since the cars are quite far apart, I just want to make sure this is going to work before I try it.
Will the MAF sensor from a 900S work on a Turbo?
I would check and see if the part numbers match. Somewhere along the line they changed the burnoff voltage for the hot wire and use the wrong one and it will burn up the wire inside.
If everything is stock then the '92 turbo is the 2.0l...the '91 n/a is the 2.1l...they have different ignition systems and the MAF's arent' interchangeable.
