1 - 13 of 13 Posts
Well, I've found out what the problem was with the '89 gearbox: the RH wheel bearing/hub.
Today the bearing was replaced and now the grumbling/grinding is even worse :eek: Doh!
So, the hub needs replacing: I have a spare pair of hubs that I know are fine from the old '85: can I swap them, ie put an '85 RH hub on the '89 and keep the '89 caliper..... The brake discs are vented on the '89 and non vented on the '85: will these swap over as well?
Bloomin' car, at least I know what the problem is now :D
Cheers,
Fraser
Doesn't matter: I have 3 spoke wheels for both hub patterns. :D
All I am bothered about is can I use the old hub on the new car with the new brake disc and caliper?
Which bit are you wanting to change over just the hub, or the whole upright ? The whole upright will fit but you'd probably have to take the brakes from the old car too.
From a look at the parts listing the hub for vented is different to non vented disc, so swapping just hub doesn't look good.
Moderator
Matthew,
Can you confirm that your commentary on the images is correct? "Steering 1986-89" suggests that the control arm / bearing carrier - item 1 in the image is the same for pre and post front handbrake cars. The difference between them seems to be down to the actual hubs - item 1 in both brakes images and the discs.
So, presumably the crucial bit Dr Rock wants to replace is the one bit that is not suitable!...
Guys, the 'hubs' do swap, the upright bit that the ball joints and the steering knuckle fit into and has the wheel bearing and disc carrier on-that's the problem area.
The brake disc and caliper need to go with their respective 'hubs', but all I wanted to do really was put a different hub/wheel bearing on the car so I could check the driveshaft was alright.
Which it is, so it is definitely the RH 'hub' that is bad, despite having a new bearing in. What is happening is that the suspension components transmit and amplify the grinding/thunking noises and make it seem as though the sounds are coming from inside the gearbox/engine bay :roll:
Anyone got a RH '89 hub spare...? :D
Saab Mad
The devil was in the details... I hadn't studied the parts list closely enough, thinking that the "1986-89" diagram wouldn't contain parts that didn't fit 1989 cars. I should have spotted the mistake. Thanks for pointing out the error :D
I have amended my post with the parts list. That seems to suggest that the steering swivel member did change fr MY88 onwards.
Hello everyone:
There are a special tool to remove part number 4 on the steering diagram (not the hammer). Does anyone have a picture of it or its name?
Thanks in advance.
Discussion Starter #13
Changed the LH inner driver and axle this morning and the car is much better. Not quite there, but better. I noticed the LH wheel bearing had been hammered by the driveshaft/CV joint....
Anyway, off to get the wheels balanced tomorrow which should hopefully help.
1 - 13 of 13 Posts
